Application Keys Plugin¶
New in version 1.3.10.
The OctoPrint Application Keys Plugin comes bundled with OctoPrint.
It implements a workflow for third party apps or clients to obtain an application specific API key from OctoPrint to interact with it on a user’s behalf, via confirmation of the user through OctoPrint’s web interface. Existing keys can be managed on a per-user base as well as globally by administrators.
Fig. 11 The plugin’s confirmation generated for a new application key request.¶
Fig. 12 Users can manage the application specific API keys registered to their account via their user settings.¶
Fig. 13 Administrators can manage all application specific API keys registered to any user.¶
Workflow¶
The workflow to receive an API key for a third party client/an app via the Application Keys Plugin should consist of the following steps:
The User opens the App and gets prompted to enter or select an instance URL. Optionally (recommended!) the User also enters their username which is also their user ID into the App.
The App probes for workflow support on the Server. If this request doesn’t get an HTTP 204 No Content the App needs to direct the user to an alternative manual workflow (copy-paste API key) and abort this one. Otherwise it proceeds to the next step.
The App sends an Authorization request to the Server to start the authorization process.
The Server triggers a confirmation dialog for the User on the Webinterface (unused here) and returns an endpoint to the App to poll for a decision in the
Location
header of an HTTP 201 Created and an Authorization response (unused here).The App uses the obtained request specific endpoint to poll for a decision every second. An HTTP 202 Accepted signals that no decision has been made yet.
The User either accepts or denies the access request which makes the Webinterface send a decision request to the Server.
If the User accepted the request, the App receives an HTTP 200 OK with an attached API key response. If they deny it, the App will receive an HTTP 404 Not Found.
Workflow with redirect to auth dialog¶
New in version 1.8.0.
Instead of asking the user to open the full blown OctoPrint interface to confirm the request, since OctoPrint 1.8.0 there also exists the alternative of redirecting the user to a basic auth dialog that allows logging in and confirming the request in a light-weight dialog. To implementat that, follow these steps:
Location
header of an HTTP 201 Created and an Authorization response.The App opens a browser window with the provided auth_dialog URL for the user to log in and confirm the request. At the same time the App also uses the obtained request specific endpoint to poll for a decision every second. An HTTP 202 Accepted signals that no decision has been made yet.
The User logs in and either accepts or denies the access request which makes the auth dialog send a decision request to the Server.
API¶
Probe for workflow support¶
GET
/plugin/appkeys/probe
¶ Probes for support of the workflow.
Normally returns an HTTP 204 No Content, indicating workflow availability. If a different status code is returned (usually an HTTP 404 Not Found), the plugin is disabled or not installed. Fall back to manual api key exchange.
- Status Codes
204 No Content – the workflow is supported
Start authorization process¶
POST
/plugin/appkeys/request
¶ Starts the authorization process.
Expects a Authorization request as request body.
The
app
parameter should be a human readable identifier to use for the application requesting access. It will be displayed to the user. Internally it will be used case insensitively, soMy App
andmy APP
are considered the same application identifiers.The optional
user
parameter should be used to limit the authorization process to a specified user. If the parameter is left unset, any user will be able to complete the authorization process and grant access to the app with their account. E.g. if a userme
starts the process in an app, the app should request that name from the user and use it in theuser
parameter. OctoPrint will then only display the authorization request on browsers the userme
is logged in on.Returns a Authorization response and HTTP 201 Created with the
Location
header set to the endpoint to poll for a decision.- JSON Parameters
app – application identifier to use for the request, case insensitive
user – optional user id to restrict the decision to the specified user
- Status Codes
201 Created – authorization process started, polling URL to query can be found in
Location
header
Poll for decision on existing request¶
GET
/plugin/appkeys/request/<str:app_token>
¶ Endpoint generated per authorization request to poll for the result.
Returns an HTTP 202 Accepted while no decision has been made yet, an HTTP 200 OK and a Key response if access has been granted and an HTTP 404 Not Found if the request has been denied or timed out.
The request will be considered stale and deleted internally if the polling endpoint for it isn’t called for more than 5s.
- Status Codes
200 OK – access granted, API key in response body
202 Accepted – no decision has been made yet, continue polling
404 Not Found – access denied or request timed out
Decide on existing request¶
POST
/plugin/appkeys/decision/<str:user_token>
¶ Endpoint to decide on the authorization request.
Expects a Decision request as request body.
Returns an HTTP 204 No Content on success.
- JSON Parameters
decision – boolean value to indicate whether to confirm (
True
) or deny (False
) access
- Status Codes
204 No Content – success
Fetch list of existing application keys¶
GET
/api/plugin/appkeys
¶ Fetches a list of existing application keys and pending requests registered in the system for the current user.
If the additional optional parameter
all
is provided and the user has administrator rights, fetches a list of all* application keys and pending requests registered in the system for any user.Returns a 200 OK with a List response in the body upon success.
- Query Parameters
all – Fetch all application keys and pending requests from all users. Requires administrator rights.
Issue an application key command¶
POST
/api/plugin/appkeys
¶ Application key commands allow revoking existing application keys and manually generating new ones. The available commands are:
- revoke
Revokes an existing application key. Must belong to the user issuing the command, unless the user has admin rights in which case they make revoke any application key in the system. Expects the key in question as parameter
key
.- generate
Generates a new application key for the user, using the application identifier provided as parameter
app
Upon success, a status code of 204 No Content and an empty body is returned.
Requires user rights.
Example revoke request
Revokes the (fictional) key
aabbccddeeff112233445566
.POST /api/plugin/appkeys HTTP/1.1 Host: example.com Content-Type: application/json X-Api-Key: abcdef... { "command": "revoke", "key": "aabbccddeeff112233445566" }
HTTP/1.1 204 No Content
Example generate request
Generates a new key for application identifier “My awesome application 1.0”.
POST /api/plugin/appkeys HTTP/1.1 Host: example.com Content-Type: application/json X-Api-Key: abcdef... { "command": "generate", "key": "My awesome application 1.0" }
- JSON Parameters
command (string) – The command to issue, either
revoke
orgenerate
key (string) –
revoke
command: The key to revokeapp (string) –
generate
command: Application identifier for which to generate a key
- Status Codes
204 No Content – No error
400 Bad Request – Invalid or missing parameter
Data model¶
Authorization request¶
Name |
Multiplicity |
Type |
Description |
1 |
str |
Application identifier to use for the request |
0..1 |
str |
User identifier/name to restrict the request to |
Authorization response¶
Name |
Multiplicity |
Type |
Description |
1 |
str |
Application token to use to poll for the decision. |
1 |
str |
An URL with which a dedicated auth dialog can be used for the user to log into and authorize the request. |
Key response¶
Name |
Multiplicity |
Type |
Description |
1 |
str |
the API key generated for the application |
Decision request¶
Name |
Multiplicity |
Type |
Description |
1 |
boolean |
List response¶
Name |
Multiplicity |
Type |
Description |
1 |
list of key list entries |
Keys registered in the system |
1 |
list of pending list entries |
Currently pending authorization requests |
Key list entry¶
Name |
Multiplicity |
Type |
Description |
1 |
str |
API key |
1 |
str |
Application identifier |
1 |
str |
User ID of the key’s owner |
Pending list entry¶
Name |
Multiplicity |
Type |
Description |
1 |
str |
0..1 |
str |
optional: User ID of user who can grant or deny request |
1 |
str |
Token to grant or deny request |
JavaScript Client Library¶
OctoPrintClient.plugins.appkeys.
getKeys
(opts)¶ Retrieves registered keys and pending requests for the current user.
See Fetch list of existing application keys for more details.
- Arguments
opts (object) – Additional options for the request
- Returns Promise
A jQuery Promise for the request’s response
getAllKeys
(opts)¶ Retrieves registered keys and pending requests for all users.
Needs administrator rights.
- Arguments
- Returns Promise
generateKey
(app, opts)¶ Generates a key for the given
app
and the current user.See Issue an application key command for details.
- Arguments
app (string) – Application identifier
- Returns Promise
revokeKey
(key, opts)¶ Revokes the given
key
. The key must belong to the current user, or the current user must have administrator rights.See Issue an application key command for details.
- Arguments
key (string) – Key to revoke
- Returns Promise
decide
(token, decision, opts)¶ Decides on an existing authorization request.
See Decide on existing request for more details.
- Arguments
token (string) – User token for which to make the decision, as pushed to the client via the socket.
decision (boolean) – Whether to grant access (
true
) or not (false
).opts (object) – Additional options for the request
- Returns Promise
probe
(opts)¶ Probes for workflow support.
See Probe for workflow support for more details.
- Arguments
- Returns Promise
request
(app, opts)¶ Starts a new authorization request for the provided
app
identifier.See Start authorization process for more details.
- Arguments
- Returns Promise
requestForUser
(app, user, opts)¶ Starts a new authorization request for the provided
app
anduser
identifiers.See Start authorization process for more details.
- Arguments
- Returns Promise
checkDecision
(token, opts)¶ Polls for a decision on an existing authorization request identified by
token
.See Poll for decision on existing request for more details.
- Arguments
- Returns Promise
authenticate
(app, user, opts)¶ Convenience function that probes for support, issues a request and then automatically starts polling for a decision on the returned polling endpoint every 1s, until either a positive or negative decision is returned. On success the returned promise is resolved with the generated API key as argument. If anything goes wrong or there is no support for the workflow, the promise is rejected.
Example usage
OctoPrint.plugins.appkeys.authenticate("My App", "some_user") .done(function(api_key) { console.log("Got our API key:", api_key); }) .fail(function() { console.log("No API key for us"); })
- Arguments
user (string) – Optional user identifier
- Returns Promise
Source code¶
The source of the Application Keys plugin is bundled with OctoPrint and can be found in
its source repository under src/octoprint/plugins/appkeys
